I cannot get my Ahhc to work properly. I know it’s a average at best on the 500 series, but has worked better in the past. On my Cebis it only acknowledges it when the gauge on the macdon is at 4. I get very little volts out of the potentiometer on the macdon but not exactly sure which wire I am supposed to be going to as there are three. I get no volts when I unplug it out of the potentiometer. I have moved the potentiometer to try to raise the voltage per the manual with no improvement.
Any thoughts?
580r - macdon fd-75
Does it use a cable? Does the cable/indicator move smoothly and correspond to header ground pressure? Three wires, likely one is 12 volt, or 5, the other a ground, the third is the signal wire going back to combine to tell it where the pot is.
See attached. 12V on the Orange wire, Ground on Black. If you have those, and the signal wire (green) is not changing much, you have a sensor or linkage problem.
Discussion Starter #4
Well I found the issue why I did not have the combine power, but now I don’t get an “outgoing signal”. Is it possible I could also have a bad potentiometer? Can I use any of the other ones on the combine (feeder house height, header speed) to swap it out?
Yes, macdon did use a Claas pot on the headers. It likely could be swapped, but I bet that isn't the issue, could be though.
Headsight makes a lateral tilt kit for the macdon. It uses a left and right sensor so it enables hydraulic tilt in the combine automatically (like macdon should have made from the beginning). A great benefit to this on a Lexion is with this kit, the combine does not use the Macdon heigh sensor setup, or those pesky cables that control the sensor that so often fail.
If you have 12V & ground at the sensor, but no variying voltage out as you mover the arm....yes, bad pot (or shorted output wire)
