I am having issues with the top variable speed pulley falling off on a 585 header drive. It keeps breaking the cap bolt behind the hydraulic piston which holds the pulley onto the shaft. Then if you’re real lucky it all falls off 🤦🏻♂️
Only get around 50 hours run time, check it and bolt head has broke again…
Anyone found the cause for this? Before I rip it all off and put a fixed speed set up on.
