Okay, enough already! I've seen enough here to know this is deviating from the original topic, so please stop the combine wars or off-topic posts will be deleted. The first 3 posts are the only ones really on topic, here.
I have to agree with Kirschenman and TxFarmer's first posts. I sure did not see Kirschenman as being "evasive," but rather just saying the life of a combine is indefinite. Only an indeterminate answer. I concur. One only needs to look back at Jon Hagen's old combine to understand this.
TxFarmer also has a valid point. Not everyone wants to keep replacing tires, separator components, sheet metal, finals, trannies and even engines as well as all the normally-replaced, high-wear parts for a single combine to be eventually passed down to second and third generation farmers.
Realistically, 3,000 sep hours does seem like a rather short life--in fact, way too short--for any combine. If I could only expect a $260,000 or more combine to only last 3,000 hours, I'd HIRE it all done! I see a lot of 5,000-or so houred Flows and Max's with as much, too. Still decent, sound bines.
I don't know what all has been replaced over the years, but I seriously doubt it's been through 3 sets of tires, 2 finals and 3 engines by then, either! Good grief!
Quote:I hear 1500 on a sts and their shot a 2388 will last forever esp if you put extended wear parts in them the augers and tin work are the weak point
That's another thing, Farmertony. You just said yourself, you "only hear it." Now I want YOU to stop and just THINK about what you said because it is mindless ramblings just like this, that CAUSE much of the color, brand or even combine bashing that goes on here......
Just what kind of logic could possibly dictate that one combine will only last a paltry 1,500 hours while another could last forever.....???
Don't you think that either or more logically, BOTH brands of combines could "last forever" if given all correct replacement parts, including those special high-war ones along with augers and tin?
Get back on track! Stop the annoying bickering over who has "the best...."
9520, I do hope the 3 of us have given you a basic answer, based on what we've seen with combines.
