Front right wheel seal was leaking on my TM 175 with super steer. Took it into dealer, they found a cracked hub and king pins were wore pretty bad. Everything was replaced that needed to be. Feeding with it today and snapped the pin that holds the steering linkage in place on the side they worked on. Something did not get adjusted right on the super steer when the new parts were put in? This was a inch and a half pin on outside end of linkage, not the steering cylinder. Anyone with any experience with super steer other than its a pain in the *** when stacking hay?
