is deflector behind shoe dropped down, do you have cupped deflectors, on spreaders, might want to make more agressive, are there more holes to change adjustment, one other thing comes to mind, did you remove spreaders and install them wrong, yes they will wrap, normally not a real big problem, new style couplers, with plastic coupler above helps alot, if this what you have, where is it wrappin top of shaft i am assuming, scott.
Thanks Scott. Deflector up. Vanes fully aggressive. It wraps around the cone & winds tight at the top around the plastic pipe. It is worse where crop is thick. I will have to remove the spreaders as I'm worried about damaging the rubber shield and also starting a fire. Allen.
