Great state of Louisiana
No guy mixing chemical. Haul sprayers on sprayer trailer and mix chemical on same trailer. All a one man show
Awesome, you should put that in your profile so we remember.
I am a one-man show too and often suck out of the top and bottom of totes, if the scale is not visible or accurate enough I measure and put a pen mark on it. The thing to pay attention to is that if you move the trailer the liquid in the tote may not be at the same spot as before and you need to re-measure.
Here is some pictures of my water trailer. Maybe you can see the suction valves in-between the pump and Handler, I have several hoses that I put on there to draw from barrels and totes on the deck. I am quite happy with it.
[/QUOTE
That seems like the trick for me. Do you habe problems with foaming somce i assume you start sucking chemicals when you're pumping water into sprayer?
