1 - 12 of 12 Posts
So I'm looking to upgrade from my 1660 case and found a decent deal on a very well maintained 8780 combine.
Knowing very little about these "newer" Massey combines aside from the general condition and how well it has been taken care of I'm not really sure what to look out for?
Also there aren't very many of these in my area and I'm kind of curious why, design wise I think they are very simple and I like the idea of the hydraulic rotor. Also what is the availability on getting parts for them?
Anyways the only thing that kind of concerned me was when the rotor was engaged running empty obviously the combine seemed to shake quite a bit. Is this normal? Or something to be concerned about with these machines?
Thanks!
The 8780 is better than the 8780xp in the engine maintenance costs.
The xp has the cummins caps fuel system and that is one costly pos.
I think those MF rotarys aren't just the worst machine.
Lower repair costs compared to CIH I think.
8780 not a super big capacity machine though.
Really it should not shake if the rotor is in balance.
Run the rotor speed up and down see if the vibration obviously varies with the rotor speed.
That must be done from the seat as the rotor will shut off once the operator gets off the seat.
I know with the TR combines I always used to watch the outside cab mirrors as an indicator of vibration.
If the mirrors vibrated too much the mirror shakes pretty obviously on a TR.
Either the rotor or chopper are outta balance. The 8780 will have similar capacity as a 2388 but with the bigger sieve area a they actually do a better job.
No experience with Massey in that era but were some of those hydraulic drives a little weak at getting the engine power to the rotor?
Discussion Starter #6
Thanks for the replies, I was actually more so looking for a 2188 or 2388 and then this popped up and from the pictures I could tell it was very well maintained and even looks better in person. The farmer is just retiring.
Before I hand the cheque over I'm really going to go over it with a fine tooth comb.
The only thing I could tell that I didn't care for was how much it seemed to shake with the rotor engaged.
He did say he just changed the chopper knives they have 1 season on them also did the rub bars A few years ago which likely could put the rotor out of balance maybe. Is this something that should be concerning should the rotor be out of balance?
Don't kid yourself there is parasitic power loss through the hydraulic rotor drive compared to belt drive rotor.
I combined right beside a friends Deere 9650 with this 8780 xp of mine, gave him a hand when weather was bad and he got behind.
No way I can keep up to the JD.
Well depends why rotor out of balance?
First thing comes to mind is rock damage.
Maybe some of those rotor knives fell off or something? or someone removed them but not evenly.
Only way to know is get that big tin bolted to the concave off the left side and look at the guts..
I came across a MF 8590 once that had dirt getting inside the rotor.
That's definately not helpful for balance.
Depends if you can find someone to balance the rotor in the machine and what they charge you to do it.
If rotor has to be removed from the machine that's work as it always is.
I never tried an 8780. Yrs ago a dealership let me use a 8570. Did a beautiful job in wheat . Was under powered and the rotor didn't have the kit to keep rpm constant. All in all I liked the concept and it took a while getting used to feeling the combine twist driving that big rotor. It was a challenging harvest that yr and my N6 could out combine it capacity wise. I made up my mind in tough canary seed when it constantly plugged and the gleaner kept trudging along. Now yrs later I have purchased a 9790. Way different machine, as one would expect, yrs later. The 8780 was the next step to towards the 9790 so it should be a great machine. Yes a hydraulically driven rotor loses power compared to a belt driven one, but when you are plugged, which I don't do often, you can open the concave, reverse the feeder house, push a button back and forth, reversing and forwarding the cylinder until the obstruction is gone. So easy it's pathetic. Never leaving the cab! Never using a bar! Ask a NH owner or JD guy how the process goes. This new stuff likely has simpler unplugging procedures in place but yrs ago Massey was the simplest IMO.
Drop the stone trap door and look at the metal in there it wears thin all replaceable or weldable. Behind the front beater and rotor inlet look at the metal there. Look at the clean grain elevator divider in the middle. They can wear there and replacing the elevator is around $4000. Bubble up auger and tube in the tank. And upright tube on the unloader. I ran a 8570 and an 8780xp. Both 25 ft platforms and 8 row heads. 3.5 mph was a good day in heavy soybeans. Corn was never a problem. They're good simple machines. Parts are common. There be a learning curve to setting them but I can always get a clean sample and minimal loss. The key is to not over thrash.
Discussion Starter #11
Ended up buying the combine we ran it before I handed over the cheque and it must have just been in my head.
I found out it has an airfoil top sieve how well do these work and how does a guy go about setting them for canola and soybeans?
I have a 8780xp went from a 8780 both good combines easy to set . I like the two speed gear box and other improvement's on the xp. But yes the caps fuel system is a true pos. I just lost the accumulate have done this four times in 4500 hours. This time put the new one on ran it about two hours the crankcase is about a gallon and a half to full of diesel. The 1500 part is bad lucky I think the engine in ok. I have a hilco leveler and running in steep hills is a added challenge it does a great job. I have cut wheat, soybeans, canola, Barley and salflower.
1 - 12 of 12 Posts
