Just wondering if anyone knows whether a Case 2011-2012 Model 2152 header will fit on 2005 Case 2388 combine at all?
I think it will. You just need the right adapter for it. Most of the ones you see for sale are set up for the flagship combines.
Changing the adapter faceplate and the electronics was around $6000 last time I looked at it a few years ago. For best results the 2152 needs an auto header height system. Also will need a modification to add header tip hydraulic control to your combine. Oh and depending on the year of the header it might need a different bracket for the header tip cylinder so you don't smack the underside of the cab with it when you raise the feederhouse.
