1 - 9 of 9 Posts
Is anyone cutting peas successfully with Macdon 960 header. Reason for asking was dealing on honeybee header for gleaner r62 and a 960 Macdon was traded in in nice shape. Honeybee is a 2003 Macdon a 1998 but half price. Any opinions would be appreciated thanks.
Used to run a 962 in peas. Worked ok, but would of been a lot better with the hyd tilt option that the new header we traded on has (FD70). If you have that and a hyd/fore aft on the reels, you should be able to do an ok job with a macdon (hopefully the peas are still standing ok). I have no experience with the honeybee, but the newer model may have some improvements over a 960. The 962 addressed some of the issues of the 960 such as wobble box etc.
We've never had our 36ft 960 in peas but it has split lock washers pushed onto the flighting on the feed auger. They help it bite the fluffy stuff and make it feed.
Tci go with the honeybee, you need the retractable finger feed drum to squish the fluffy peas so that feeder chain will accept the material, the 960 always piles up on center canvas, I have and run both...the honeybee is twice the header and you can keep combine full which is so important in peas so that you are not cracking
1 - 9 of 9 Posts
