I have a fr9060 and has problem with high temperature in the main gearbox what can cause this issue and which is the normal temperature of the main gearbox
thank you very much
Could be a tight bearing. Also seen to much oil in a gear case can cause it to over heat. Is there an oil cooler that could be plugged. Wrong grade of oil maybe. I had a fan drive for an air bar on a flex head that would boil the oil because it was running too fast. Made a custom fan to move air past it and keep dust from collecting and made a ton of difference. Too hot will cook the seals.
Discussion Starter #3
Thank you very much the problem has solved by changing the oil and filling the correct litter in the main gearbox
