This question got buried in another post of mine somehow, but someone else told me to tilt my sieve a little bit, because all the corn was overloading the right side. How can i do that and how much do you recommend? 1', 2' maybe?
On your pro 600 monitor go to the main menu then choose Toolbox then at the bottom pick the tab that says clean. On this page there should be a listing for Sieve offset. Start out with 1 degree and if that doesn't work increase it a little more. You might also want to check that your concaves are shifted all the way to the right. There are 8 bolts you loosen and use the adjustment bolts to drag it to the right.
