1 - 20 of 73 Posts
Hi,
I have heard about Massey Ferguson new series of 500hp tractors which MF is to introduce this autumn. There are some considerations that they will get Fendt 1000 in red...
Has anyone heard about it yet?
Red Challengers or Fendts? Didn't think the MF line had the 1050 equivalent, thought the Challenger was just a yellow Fendt, assumed the Fendt was the first to that party but do not know for sure.
The 1000 series are Fendt's painted Challenger colors. The MT400, 500, and 600 are MF's painted Challenger. The 700, 800, and 900 are Challenger's.
Discussion Starter #5
Our local dealer said that there would be a new 500 hp serie wheel tractor in 2020. Some peoples claim that Massey Ferguson is going to have new tractors. Massey has bought a new buildings and they are about to produce 14 new series of tractors in Beauvais in France. Fendt produce yellow Challenger for U.S. and Australia maybe, and they are adjusting production capacity for 1000 serie in Marktoberdorf. There is something strange in this. Our locall dealers are scared of Massey´s having 1000 in red...
They need to put tracks on that 900 series 4WD and nothing would touch them. Even my 965 on 800's will out pull what my Quad-trac's used to do, at half the RPM...ha ha Maybe they are updating the 900 series and giving Massey access to it, I have no idea really. At this point I really think they need to give all dealers access to the full line and badge them however they choose. Around here anyways there isn't Massey and Challenger dealers across the street from each other. The whole line is top notch if you don't count having to add in aftermarket GPS equipment.
I don't recall which series of 900 series you have, does yours have the Cat or SISU engine?
I can't believe that they don't have that figured out. It seems like every time you turn around they have a different GPS system. Are they still trying to use the TopCon equipment or have them moved on from that?
I have a 965C and my 865 is an E series. Both engines have very good torque, Sisu is quieter but of course burns DEF. Both tractors have their strong points and both pull really well. About 2000 hours on each tractor now with no downtime on the 865E and only two minor repairs on the 965C, been really good units.
The Trimble stuff is pretty easy to hook up with a pretty reasonable platform package but it still is an add-on. The CNH equipment seems to all come with the GPS equipment included, not sure about Deere. I think Topcon might be the choice for AGCO in other parts of the world and I think it can be ordered with that, but nobody here is running Topcon guidance. Point is nobody is running a 4WD or row crop tractor without guidance, should be built in.
It’s strange what goes on sometimes. In Nebraska on a scientifically controlled test a Challenger 965C on a 50% pull at 1537 RPM produced 211 DB HP.
A 600 Quadtrac on a 50% pull at 1478 RPM produced 248 DB HP.
A 965C on a 75% pull at 1539 RPM produced 314 DB HP.
A 600 Quadtrac at 75% pull at 1471 RPM produced 367 DB HP.
I wonder if there was something wrong with that C18, or if it just seems like it sucks for its size sometimes???? ;);)
https://tractortestlab.unl.edu/documents/mt965c.pdf
https://tractortestlab.unl.edu/documents/Case IH Steiger 600 Quad.pdft
I agree, the 900 series AGCO’s will also need to be badged or at least sold by MF dealers so large producers can get their tractors where they buy their IDEAL combines.
I can't explain what goes on at Nebraska test track. I would say there is some pretty suspect stuff comes out of the NTTL, any chance they are not as pure as the wind-driven snow like just about every other organization on earth?:sFun_whistle: I'm just glad we don't farm on pavement. I do know pulling the same implements up the same hills that there is really no comparison in the field, my 965 is weighted pretty heavily though. One of the really nice things about the larger displacement engines is they seem to hang in there at below 1500RPM, which the CNH and Deere 13L engines don't. Just makes it a less stressful experience. I did drive a 9620RX I believe it was(15L Cummins) and it did have some good torque, perhaps the Versatile would be same.
Australia only gets fendt 1000 series. We do get yellow challenger tracked tractors though
We regularly run out of power in that exact situation with our 620s pulling a 60ft disc drill with 7950. As soon as it gets pulled below 1500 rpm they fall off a cliff. I also look forward to a 900 series on four tracks.
There is no replacement for displacement. Our old 903 cummins (15L) can take off idling with out a bat of an eye. Torque way down at low rpm requires displacement. In hills where rpm's can get challenged some of these high hp smaller displacement engines hit a breaking point fast where it just falls off a cliff.
For the life of me I can’t understand why people insist on doing that for the sake of not selecting a lower gear. Most modern designed engines have nearly flat torque curves for emissions purposes, with an abrupt torque fall off as it reaches maximum RPM to limit its maximum horsepower, thus creating a wall of torque as it is lugged back down toward 2000 RPM. Running a 681 horsepower tractor with a perfectly flat torque chart, lugged down to 1500 RPM reduces it to about a 510 horsepower tractor.
The up side is a 12 litre engine can produce over twice the horsepower of a venerable old 15 litre Cummings. ;) If you run it wide open, and don’t lug its guts out.
True enough, when an engine is lugged down 500RPM from 2000 RPM it will only be accomplishing 75% of the acres it was, so it better feel like it has the world by the tail.
Discussion Starter #17
Agco put tracks on 900 series when they tested tracks for Ideal. I think there would not be any problems with it but they probably don´t want to offer four track tractors.
Yeah but who wants the engine spinning at 2000RPM when you can do it at 1500 without fear of it crapping it's pants.
The 13 liter engines in my Volvo trucks run 1100-1400RPM all day and behave just as a diesel should, why can't CNH and Deere do the same thing?
It's not about what they want, it should be about what the customer wants.:wink:
Cause you would have to build a bigger driveline/transmission to run that slow in a tractor all day long at 80-90% power like lots of tractors do.
What would be the average power usage on your trucks? Less then 1/2 I would guess?
Only to the first set of gears right? Then it could be put to whatever ratio?
All over the place, sometimes steady full power but not for all day like a tractor can be at. The characteristics of the Volvo(and many other OTR) engines compared to Iveco especially are much different.
1 - 20 of 73 Posts
