Has anyone found a max amount of dry fertilizer that you can put through a seedhawk without plugging the primary hoses solid? Twice today, after seeding 1100 ac of canola with 295 lbs of fertilizer with no plugging, I've plugged the primaries including the aluminum tubes right at the rollers. After plugging the primaries going to the far outside towers during the first 80 acres of the canola, I geared down to 4.1 mph from 4.5. No issues until today. So now I'll gear down more and maybe even turn down the rate. Hydraulic for fan is maxed out. My only thought that the plugging must start when there is more hydraulics used when the openers are raised/lowered, resulting in the fan to drop rpms. This is in a 60', 12" spacing SCT.
