21 - 40 of 40 Posts
Discussion Starter #21
ya like i say dont really wanna use it trying to get away from nh3 is why we melting the 46-0-0.
I have 2 tons of 11-52 and 1 ton of 46-0-0 left from seeding that we mixed together to broadcast on our grass, would I be able to melt this down and spray it on the grass instead? What blend would it come out as?
sorry we are mixing 2 tons in 1250 imp gallons/1500 us gallons so 2026lbs of actual N and putting on 7 us gallons with seed and 25 or so us gallons in fert shank.
Are you putting a nitrogen stabiliser with this mag spec?
Lach
After uera is melted, how long can it sit in a tank till it needs to be circulated again after melting is done, will it build up in tanks after some time??
I think once it is melted it is in solution. I did some 10% stuff last year and apart from the dirt that settled to the bottom of the tank it was fine, but that was only a few days. I did see some totes of 20% stuff at the local inputs place but it was like 10X the cost of the actual N!!!:rolleyes:
I bubbled air through mine to mix, was fast and easy.:smile:
Locally here, we have an acid fertilizer dealer/mad scientist that makes a 25-0-07. He says 18%, maybe 20%, is about as potent a concentrate you can melt from urea. However, if you add a little sulfuric acid to the pot, it warms things up nicely, and you can shove another 5-7% N into the solution. Anybody I know that has used his product says it holds solution fine, and for top dressing wheat is a bigger bang for the buck.
DISCLAIMER.. I would suggest doing some research before anybody went dumping sulfuric acid into water though. That being said, this guy claims about a 1/4" of sulfuric acid in the bottom of a pint jar, and then dumped into a hot tub, will eliminate the need for a water heater and all those pesky chemicals.:sFun_doh2:
I melt 4ton urea in 12000 litres water.
So you end up with 16 t of 11.5% N?
That about as high a stable solution as you can chance when made by this method?
What total volume do you end up with, curious how much specific gravity is raised?
16/total volume in cubes.
Your right Don, 11% would be about the best you could do @ 15 deg. We top dress here between June and August, I'm guessing the average temperature of our water is 12 deg by then , so my main mix is approximately 2t of SOA fines plus 1.2t prilled Urea. The SOA is a lot easier to dissolve, we like to use it early on our sandier soils. Later on after flag leaf , we switch to a urea only brew. In wheat the urea would be mixed with copper and a fungicide, hopefully to keep the protein up.
At 11% can you spray that straight onto the crop, or do you still have to mix/dilute it with more water when you add to the sprayer?
N is taken up by the roots, not the leaves. You will get a flash appearance thru foliage. Seems like a lot of work just to dump N on the ground.
I sprayed my 10% solution directly on the crop with flat fan nozzles at milk/soft dough stage with no leaf damage.
I did hear someone mention a possible component in offshore urea called bi-urea??? that causes leaf burn. Domestic product has this removed apparently. I have not been able to confirm this to see whether it is correct or not. Not sure how you would know whether your product is safe if you did not know the exact source. Maybe someone knows more?
The research I've read has shown a small amount can be taken into the plant, greater the leaf area the more uptake. Any urea missing or dripping off the leaf would be available for root uptake.
We are in a lower yielding area , so are in crop N applications are low and very seasonal. Melting urea would not be practical if you're using rates of 100kg/ha or greater over large areas.
Sulphate of ammonia fines are difficult to spread , so I find it practical to melt it and spray it 40m wide.
Herbicides and trace elements can also be added to the brew, this reduces the number of passes per season.
Seen this topic quite a while ago, never did this though. Other than a foliar spray would be impractical for us to side dress as the amount applied would involve a LOT of liquid. Got me to thinking how it would work to make a UAN solution, but guessing it would be very hard to get the 34-0-0 needed. Wouldn't be hard to do if you had the right set up, a way to heat water to about 200F along with plenty of agitation.
We have been dissolving 6,000 KG into a 4,000 US gal tank , circulating with a 3" honda pump + air . We end up with approx 1.6 lbs N per US gal.
For application onto wheat we dissolve 3,800 kg into the 4,000 gal tank and end up with approx 1 lb of N per gal.
UAN to Urea cost per lb of N this season is almost $.08/lb for us , so there is a $ saving and that is putting $500 / batch is for mixing costs , tank and pump use.
We are actually putting our 2nd and 3rd pass N on our wheat with flat fans , we have trimmed 20 lbs of N per acre and maintaining and improving yields in our winter wheat . Last season's trials with same lbs of N streamed vs foliar showed a dramatic difference in protein in our soft red , to a point that we were told to blend it down since it was too high .
So far this season we have dissolved just over 120 mt.
21 - 40 of 40 Posts
