Meridian is better in load out department and just buy 12in.
Gas auger engines aren’t the most fun things to deal With when it’s cold either.We like our springland ult 40’s better than our meridian 12x40. Loads b’s in 15 to 20 minutes kolher gas engine, won’t rust as bad doing fert. And built in hopper. Als a lot nicer than dealing with a little Diesel engines in winter. AGI makes one similar to the springland too.
Back to the OP, the meridian is the solid option for truck loading augers and I'd also suggest going to the longer 46'. It allows more reach under hoppers, overtop of high exhaust stacks, or for filling smaller bins. Compared to the TL 10", the HD 10" using a slightly heavier frame, triple belt, and slightly heavier tube gauge. Avoid the kohler and stick with the vanguard motor.
Lots of suggestions for going to the larger 12" that is similar in price with more capacity and better longevity. If it fits your operation, go for it. Especially for moving grain around a dryer or getting another load to the elevator each day, that extra capacity is really nice.
I bought a 10x46hd meridian 3 years ago I asked about the EFI engine but the dealer said they had some trouble with them and went back to just the regular carbed engines. Maybe the efi are working better now. An auger engine seems to be one of the most neglected things maintenance wise so the less to go wrong the better.T
Thanks to all who have responded. Unfortunately a bunch of my hoppers are pretty low so even a 10" will be tight to get under so 12" or U trough might be very tight. I only use it for hoppers and canola normally as I have big flats which I use a swing away to unload normally.
Seem to be a lot of Pro Vanguard folks over Kohler!
Looking at a 10" HD46 meridian with 37hp efi vanguard. What kind of life expectancy should one expect out of those motors? Meridian has better lights and switches too.
THx
I have only used my 10 by 46 HD for the second year now, but that said I had no gas blow thru into the oil pan so I would assume that will improve the performance of the vanguard over the years. Another advantage with the double front axil is the auger is balanced nicely and it moves smoothly thru snow or minor ruts in the yard. I have been really impressed.What kind of life expectancy should one expect out of those motors? Meridian has better lights and switches too.
