Good evening all, new member here from SE SK. We have a MF 220 swather that is having electrical issues and I wonder if anyone else has run across similar things. When we turn the key on, the complete machine becomes positive albeit very weak. If I hook a test light up to the negative battery terminal, I get a weak light when I touch the frame, engine, etc. If we turn the key to start, the test light brightens. The swather will not start, and turning the key on does not illuminate the overhead console. Also, there is no power to anything-no lights, fan, radio etc. I have tested the 10 A and 30 A relays on the RH side of the frame, and all seem OK. At first, I thought the issue was the accessory solenoid, but now I think I have some other issue allowing positive voltage to flow to ground. Any help is appreciated.
