1 - 2 of 2 Posts
Where do guys tie in for hydraulics? I switched the rotoshears from my
old swather and reused the hoses which fit best tying into the right hand canvas motor return and running both rotoshears off it with quick couplers.
When I start the machine the rotoshears turn a half revolution and stop, not the safest and I'm going to have to fix that somehow.
Also now when it is running there is a squeal from the left side. Everything turns fine but under a heavy load it squeals pretty good. I assume it is the pressure relief valve for the canvas drive? I can just turn the relief valve up a bit or should I replumb everything and run the shears off the reel drive? Or run each shear off the closest canvas motor instead of 2 off of one?
Thanks
Discussion Starter #2
Cranked the relief and its a beast. Not sure about the shear turning on start up though?
1 - 2 of 2 Posts
