Running MF 550 and a 9113 with hydraulic reel Drive. Reel started running erratically now won't run at all. Read online that you should be able to loosen the jam nut and run the screw out on the back of the hydraulic controller to essentially bypass the electric control. Tried that, didn't work.... any ideas what the issue could be? Where to start?
Well it could be more serious then.
check the usual stuff.
Got oil?
Any quick couplers locking up?
Drive belt tight?
Those cessna pumps aren't overly reliable maybe it packed it in?
Piece of junk stuck in the relief valve?
