I have a 76 L. I was having issues with the reel speed, height and auger swing I think I had a short somewhere and ended up running all new wires to these coils also at first the header lift was being affected.
The auger swing and reel speed were burning fuses and at the same time the hyds quite working completely on the secondary valve. I think I have all electrical issues fixed the fuses are holding. Now I notice the master valve is leaking very bad. I Pulled it apart and replaced the big O ring that goes up inside the valve body.
It is the correct part number but it seemed too big. I finally just put it in there and tightened it down but the leak was as bad or worse. Today I ordered a complete O ring kit. What did I do wrong on the O ring installation? I pulled it apart today and that O ring was broken. Also none of the hyd functions are working on the secondary valve.
