I'm currently using a 8820 turbo to harvest a light crop. The reel only turns slow (dial in cab does nothing). Any ideas where to look or if there's a valve I can adjust to get it turning faster.
We have a John Deere Combine 9500. from 1996.
What is the problem when you switch to to half engine speed nothing happens? it only work on idle and full speed.
Everything seems to be tight where they both mount but are wearing on each. It wore the crank assembly on the top completely off ? I wouldn't think they should even touch each other? Did take belt off to see if the back would turn freely even with the top out but turned very hard by hand . DID...
