when downshifting while ripping in 5 th the tractor skips 4 th gear and goes directly into 3 gear is that normal?
Yes thats normal. Versatile does the same thing. It is to protect the transmission. The engine also derates. Real pita
Yes's this is normal under high draft loads, . Once the gears change down from 5th to 3rd you can change back up to 4th gear. It is a design feature that was built into the soft wear for all the mt800 A B C series
Under low draft loads this will not happen. Hope this helps best regards.
