Going to cut hay tonight driving to the field and a alarm goes off under the pto switch or somewhere under there. You put it in forward it sounds. U put it in neutral it quits.ran the codes one is 62 other is 27. But on the dash instead of speed it has a hour glass and then it has 300 with a 7 under that. Don’t know if it’s related but having problems with my blower motor fan the last couple of days. U can turn the switch on and the fan will blow. Then u turn it off then back on and it won’t work at all. Crazy. Any help would be appreciated.
Follow the ground cable from battery to the transmission housing and check for tightness at the battery and the frame. There should be several grounds in that area. Code 27 is F/N/R neutral lamp not operating. Code 67 is PTO and engine speed signals do not match after 6 seconds of manual PTO engagement or after 3 seconds auto PTO engagement.
