Hello
I need your help people
My problem in the tractor is when I start driving in the filed with the tractor, I use the clutch for the first time.
Then when I finish the row I stop put in "N", the wagon is been loaded.
Then when I want to start driving again, I am not supposed to use the clutch.
Just to push the push forward the stick lever and the tractor will start driving.
But it's not working, it's writing on the small screen "CP".
And after a few seconds going back to "N".
And I need to use the clutch again.
I don’t think the problem is in the micro switch.
I am not sure if the problem is in the analog sensor.
Do you have base on your experience advices for me?
Can you direct me to the part which is causing this problem?
