I have a 2005 MXM120 with a leaking steering cylinder. I got the pin out connecting the cylinder to the wheel hub (#2), but the pin connecting the cylinder to the axle (near the engine) (#8) wont budge. I've looked on Case's parts website for the exploded diagram (below) and I don't see a snap ring or anything like that holding it in place other then the screw on top (#6) which I removed. Anyone have any success removing the pin? Is it just seized in? Is their some crafty trick?
Thanks in advance!
160377
I find that some pressure from a porta power off the ground and a little bit of air hammering get those to move nicely. Just be careful with the air hammer or you will turn the mount into hamburger.
