My beeper on the warning system won't shut up. I've noticed if I turn the blower on high it will quit. After a bit I can turn the blower motor back on low and it will stay off until I slow down and then stays on. I presuming a ground problem. All sensors light up normal when I slow the RPM down. Any other thoughts. I'm going to clean up the ground wires in the console on the floor and I think their is one under the cab. Any place else. I have also swapped out the beeper box with the other machine and that didn't help. Thanks Greg
