Well my friend you thought wrong. The separator is driven through a electric over hydraulic clutch without doubt. Of course the separator runs when engine is started as it is engaged.
Let's be clear on this. It's only that clutch and nothing else.
Cheers
The hydraulic line you disconnected will allow you to spread those sheaves apart. You're going to want to take apart the other set of sheaves that are torque sensing. Right now, those sheaves are being held tight together on the belt by a huge spring and set of camms in a "can" in the center of the outside sheave.
I think you need to unbolt that can from the torque sensing sheaves, then they will separate. Alternatively, you may be able to drive a 2"×4" wedge between the sheaves to open them sufficiently to get the belt off. Too, I've used a tanker pry bar to help get them open. Regardless, you're going to want to take that spring and camm apart, thoroughly clean and lubricate it and examine it for damage.
Hope this helps.
The rotor drive hydraulic line is separate to the separator HYD. Line. Nothing to do with it. Bern done at the beginning.
The variable speed on the rotor is not the problem.
You don't seem to grasp the part I'm mentioning.
It's the hyd clutch which drives the WHOLE separator, not just the rotor sheaves.
Thanks for your help but it's not applicable to the part concerned. Cheers.
