Will worn cylinder bars cause rotor loss? The bolt heads on the bars are about half worn off. Started cutting milo today and have a lot of grain on the rear axle. Plants are still green and moisture is on the high side (17%), some lodging also which causes me to run more material. Machine is set by the book and is doing a decent job of cleaning. Rotor is standard setup. Any help would be appreciated.
Thanks,
John
Thanks,
John
