Out of those three i would say that the L2 has the most capacity, although since it is newer and probably has less hours the R40 will be more reliable. If you wanted to get a little more capacity for the money you could go a different route and look at something like a N7. The N7 will probably be as reliable as the L2 but like i said there is alot more capacity for your money there. You have probably already made up your mind between those three machines but here is an N7 that i thought would be a good example.
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5718919
Hope this helps!
Hope this helps!
