What it boils down to is that i am getting chaff piling up on the bottom sieve, chaff building up right behind the augers that are under the rotor, chaff piling up in the fan and then it finally piles up on the top sieve. Running two machines set the same way, only one with these problems. Its like i am getting no air blast from the fan, but it is at correct rpm. Have spent hours today trying to fix it with no luck. Been cutting for 3 days with no problems and then all of a sudden started getting MOG in grain tank and found problems. Man i need some HELP! conditions are 60 bpa HRWW 12% moisture. 750rpm rotor, 1050 fan, top sieve 1/2 1/2 5/8 and bottom 1/4
