Hello! I have a hydraulic cylinder that I believe was a lift cylinder for a combine. It was modified to be used on a monster truck. The cylinder body has a 2.5" diameter. And the piston rod has a diameter of 1.875". Does anyone out there know what this came off of?? *Note that the bottom rod mount is a custom add-on.
161263
161264
Almost appears both the base and rod end have been somewhat modified.
I don't recall if Massey ever put anything on their cylinders, but it seems to me John Deere used to stamp numbers on some of theirs in that approximate location.
Looks like an MH stamped into it. If that is for Massey Harris, then you need to go back to a 72, 82, 92 or older I believe.
Probably best bet is to find an (old) combine junk yard and just go snooping.
