1 - 2 of 2 Posts
Looking for advice on a 30' Case IH auger head, I have no experience with the Case heads only with JD heads. Will be using it in Wheat and Alfalfa Seed on an 8010. It will need to be a flex head as the A. Seed is right on the ground. Thanks
Well from what ive heard the new 2020 red newholland heads are pretty much set up like a deere on the underneath part..so maybe it won't be so much different
Some people have said they could go longer at night and start sooner but they were comparing a new head to a old or worn out 1020..so its really hard to make a comparison
did you get a full finger auger?
also you need to buy the extra 3 fingers and bolt them onto the side black tin...That really helps feed the ends into the header.
1 - 2 of 2 Posts
