try ur rotors at 1200, upper seive at 15mm, lower at 5-6mm. fan about 900. play with that pre seive, that makes a lot of difference.
is it showing high on the monitor? Did u get a bucketful from the machine while it was running?
If bly is easy threshing then open up sieve's and pre sieve as far as your sample is getting a smile on your face after that look what coming out ,if your happy with that set your loss mon. accordingly and that is your max cap. for that combine . think every brand will have same problem in those conditions.
Think your engine load will be close to 70% . If you want more cap you have to pull wire's.
good luck Snorton.
