Have a 01 2388 and cutting wheat. Combine sitting everything engaged at full throttle, engine RPM's are 2470 rotor RPM's are 1000. But if I push it and the rotor RPM's drop to 850 the engine is still running 2430 RPM's. The motor shows no sign of being worked or having a load on it. checked both sheaves in the engine compartment and the driver is just under 3" and the driven {the one that is on the rotor gear box} is 3 3/4" from outside to outside. I checked my cam followers they move freely, but should I be able to just grab them and spin them, with out taking tension off of the spring. Need help this combine is not performing like it should.
got belt slippage, either rotor belt or belts driving rotor, check tension on belts that drive rotor, check pulleys for wear, don't have book handy, ops manual tells ya measurement on rotor shieves, might have to take cam assy apart, possible binding due to wear, i'm guessing rotor slow down poor sample, is this something that just started? bet if you put both of sets of belt on life will be good, scott.
Maybe time to replace the disks in the clutch pack? Or maybe the little adjusting screw has loosened itself off and the pressure is too low. Just throwing a couple things out that we have dealt with and have not been mentioned yet.
Well Scott is the winner, the three groove belt that runs the rotor drive was a bit loose. (when we were putting the new three groove belt on the tensioning spring had screwed it's self into that half moon block.) And the rotor belt was not in the shieves acording to the book. Thanks to all that replied I really appreciate it!!!
