Hello, I bought a used 53' 1820 with a 1900 cart that has has the 1910 meter boxes on it. It has 3 tanks and I did the rate check on the rear and third tank with some fertilizer. I set the rear tank to 120 lbs and the 3rd to 50 lbs product rate with the fan set at 4700 rpm. I did a few short passes to check if it works and it plugged 4 of the 5 top fertilizer runs. After I spent 2 hours clearing them I noticed that the top runs have half the airflow of the bottom / seed runs. No matter where I set the air dampener the bottom runs have way more air pressure and the top run just seems too wimpy.
Any ideas ?
I read in the manual that on a tow behind the damper crank should be on the bottom, but this on is on the top, could someone have put it in upside down ?
Should there be any difference in airflow between the top and bottom runs?
I'm new to john Deere and I'm already got not liking this thing. Any help appreciated
Any ideas ?
