I looked at this cart today. I liked the electric drives and sectional control. In fact there wasn't really that much I didn't like about it. It will be interesting to see how many of these hit the field in 2016.
X2, I can't believe you guys aren't posting pictures.....it would save you typing a thousand words you know.No pictures? I haven't seen the cart yet, I assume it will be at Ag Days in Manitoba. However it sounds a lot like the meters on the new Seedhawk tank.
Short answer to all your points is yes.Don, I asked the Morris guys this question about there set up. If you shut the seed off thats going to mean less resistance to flow in those lines, So wouldn't that mean that the air from the fan is going to take the path of least resistance, and cause plugging issues in the runs that still have seed going threw them?
So I as I understand the flex coil system uses individual metering motors for each primary run, and morris uses a gear to shut off and turn on the metering, the disruption to the air and seed flow should be much the same. The morris guys told me that it isn't a problem, because of the back pressure caused by the openers being in the ground. And the air resistance from the hoses and manifolds. So perhaps its not as big of issue as it would seem? Or perhaps there was a flexi coil engineer eves dropping on our conversation and the morris guy was wanting to throw flexi coil for a loop?
One thing that I forgot to ask about was if the Dutch seed breaks would change that. Since they are exhausting air to slow the seed as it falls to the ground, perhaps thats going to cause an issue?
Yeah!No pictures?
Yes it is a similar setup to the Seedhawk.No pictures? I haven't seen the cart yet, I assume it will be at Ag Days in Manitoba. However it sounds a lot like the meters on the new Seedhawk tank.
