Hello to everyone out there waiting to harvest. I have a new Holland 9882 that has developed some wiring issues and was hoping someone might have an idea. My rear fender lights and roof lights have quit working. Fuses are not blown. Relays Have been Changed. Under the relays on the "fuse board" it looks like they have been heated up at one time ie melted looking plastic. Any help or ideas would be apprieciated . Thanks
I am not sure on a new holland but on 60 series deere had the same problem, take a look at the circuit board if you can see it, on ours for what ever reason one of the circuit pathways "copper traces" was broken, put a multimeter on it and tested for continuity. There was none so we soldered a wire on it and it worked fine after that. I know its a low probability but if you have checked that you have power coming out of the relay, I assume you checked continuity between the back lights and the power side of the relay and if thats good then I would guess something like the circuit board (assuming there is one on a nh9882)
