Cheers guys. How did you secure it to the old liner?We had the same problem, had a local fab shop build us a full stainless steel liner. Worked very well.
Thank you. Can I ask the reason for using stainless steel?We used carriage bolt and actually drilled hole's right through the spout. Works very well. About every FR that has come from our local dealer has also done it now. The fab shop used a square "punch" on the stainless liner and we just marked the holes out on the spout and drilled away. Didn't effect crop flow at all. Hence the reason for carriage bolts.
Do you know the Dimensions of the liner? I need to make one ASAP.We had the same problem, had a local fab shop build us a full stainless steel liner. Worked very well.
Better wear than mild steel.Thank you. Can I ask the reason for using stainless steel?
