Feeder chain broke, stuck up into rotor, piece of what I believe is the rotor flighting. Anyone experience this issues? Best way to remove feeder house? Should I be searching for new rotors?
Sleeve Yellow Gesture Wood Font
Tire Wheel Motor vehicle Vehicle Automotive tire
If there isn't a feeder housing boot on it check with the dealership to see if they have one you can rent/borrow/buy. Makes the job much easier, quicker and above all safer.
Feeder chain broke, stuck up into rotor, piece of what I believe is the rotor flighting. Anyone experience this issues? Best way to remove feeder house? Should I be searching for new rotors? View attachment 163795
Depends on where yiur located but i have a tr 98 that ate a rock. One side is damaged (rotir / concave) 6k for the combine and shes yours. Pm me if interested
Might not be too terrible if just the auger flight is damaged.
Or did pieces go through?
If chunks went through and the H frame is all messed up this is going to be down for a while.
Used to have a engine crane at work with a custom made bracket for the rotor shaft and I think used a long chain to the rotor for putting them in and out.
