1 - 2 of 2 Posts
My neighbour has been having fuel problems on his tractor. I5 seems the fuel is drain back to the tank when shut off for more than an hour. He’s changed the fuel pipes and sender in the tank but still no better. He’s going to check the lift pump in the morning. It happens when the tank is lower that half full.any ideas on where to check next. Thx
I’ve had that little lift pump that runs off the camshaft fail every 2500 h on a ts115a. Usually it results in low power as the fuel pressure is too low for injection pump. I would replace it.
1 - 2 of 2 Posts
