What if any advantages have you seen from this? Yield, Protein or maturity ?It looks promising from what I have seen. Like blue collar said maximum results will come from about growth stage 31 I think, which involves a separate pass. I plan to do that and have product booked for my wheat acres. Below is a picture of Harvest wheat sprayed at GS31.
EDIT: dschill the price was slightly over $12/acre
Not my trial. There was apparently a pretty good yield increase even though the crop did not lodge.What if any advantages have you seen from this? Yield, Protein or maturity ?
Then they are using it incorrectly. Proper use and data show the opposite.From anything i've hear or seen in regards to PGR application you never get a yield bump. PGR help preserve yield the plant has already built in. As we all know, lodged crops never are a good deal, especially when it's wet. Now I have heard guys say they have actually had crop damage and yield drag using PGR at the edge of acceptable timing range.
If you haven't already booked it by nov, not sure its available.
http://www1.agric.gov.ab.ca/$Department/deptdocs.nsf/all/crop14718/$FILE/au-2014-bernardin-manipulator-a-plant-growth-regulator.pdf
Manipulator has the same active ingredient as Cycocel, so what makes it any different??? Chlormequat chloride was discovered in the 50's.Then they are using it incorrectly. Proper use and data show the opposite.
Rather than me typing:Manipulator has the same active ingredient as Cycocel, so what makes it any different??? Chlormequat chloride was discovered in the 50's.
that would make sense given the root mass remains also unchanged.From what I have heard there is definitely something to be said about yield advantages even without really increasing your fertility.
As far as putting the energy more into yield and less into straw, I have been told that the height will be reduced with PGR application but straw tonnage will not change. So basically your getting shorter but more dense stalks and not really "less" straw.
