We got a 500, haven't hit my head yet but three others have, got to watch the hood sides too, they open to five foot ten... I can't believe engineers would design something for the next twenty years like that, just shows the results of city folk working in a cubicle I guess. I'm not sure of the logic behind the electronics taking ten seconds to startup and a minute to shut down, I've been told if you get ahead of them you can mix things up pretty good and take a few minutes to reset.
I've only spent a few hours driving and fooling around with it, the Cat powershift is a little disappointing so far, hopefully they can fix it, for some reason when shifting from five to four it goes directly to three, runs there for a couple seconds then shifts up to four, sometimes it stays in three. The reversing fan is a little entertaining, it goes to full suck, back to no flow, pushes for a few seconds, back to mid suction, it never seems to really stay at any setting, this is while idling. Under load it seems to do similar. Fuel gauge doesn't work, they are waiting for their third upgrade for that. Cab seems quieter then the old series and doesn't seem to get thrown around as much either. I see the glass is mounted the same, hopefully it doesn't fall out like the old one did.
Otherwise the tractor seems okay, did the fifty hour oil and filter change yesterday, seven big filters that are not too bad to get at and one coolant filter. Sometimes I wish they would do something with the threads on the filters to make them start better, that twenty pound oil filter they put on the side of the engine is a real pain to start, I might make a guide out of plastic I can bolt to the oil pan to help start that filter.
So far they've only been using it to pull the seven shank Kello Built subsoiler breaking up virgin prairie. It's operating 1800rpm in forth gear around 3mph, it pulls the engine down a few times but fuel consumption is showing around 12gph, half of what the 435 showed, I'm thinking one of these is off... They have a young lady running it that has never been within five miles of a tractor before so I guess that explains how simple it is to operate. The field is a mile square and it has Outback autosteer on it, she is in constant supervision of her boyfriend who is running the disk in the same field.
We're hooking it up to the scraper so we'll see how that works in the next bit.
