Yeah, combines as complicated as plane.
I actually don't understand your point on hook up?
As to the 20%, note I said lump all harvesting equipment, in which I include swathers.
I also made an assumption there that all swathers fit the "standard".
I know MacDon does and therein lies my beef.
I jump back and forth between MacDon and Lexion during the season, I NEVER have to look at or use MacDon controls in the wrong direction, I ALWAYS eventually use Lexion the wrong way, they are simply not logical.
Fore and aft reel and header tilt on the Lexion are also backwards to MacDon, very handy!
I was going to suggest that if you are used to CIH you could jump in a Lexion without a problem
but I think the reel and header switch positions are reversed between the two. More
As to positive transfer, yes I'll buy that, the two hours I ran a maximizer it also was backwards, but that would only be on 50 series, when 60 series came out Deere jumped on the standardization bandwagon.
I gather that you are a commercial pilot then?
Since almost all my long distance flying is Westjet I probably have not flown with you
(I see your out of Kansas) but that is still neat to know.
Don
