The feeder house on the cr is wider it's the same as the 8010's etc. I bought a 2020 without looking close enough and it had a plate that bolted onto the header to reduce the size of the feeder opening. I do believe that the drive shafts are different
The cr and cx combines do match up to the new case combines when it comes to headers, the wide new feeder house, not the 2388 size. But the header hieght does not you would have to buy new sensors the voltage is wrong. They are a couple hundred a sensor.
The honey bee will change over you will just need to buy the frame on the adapter and you move the drum to it. We did it in about 4 hrs with 2 guys. I think it cost $2500 but $700 of that was the flat face hydraulic coupler. It came with the a wiring kit also.
