I have a nitro n2xp with a 36 meter boom and a viper pro controller .just wondering how I check or change the swath width,as I'm getting overlap by about 1.5m ? I have two 9m sections each end ,and three six meter sections in the middle.
Any feedback would be useful as I need to correct this ASAP!
Happy new year.
I switched to a viper 4 so I got to think about this a little cause it's been a year now but you need to get into machine configuration, accuboom node, verify sections and width, and make sure boom one is set to zero for width set the other 5 sections as 2-6 if they are not set that way it will not record area from section 5. Hope this makes sense
If you go to boom set up check your overall width to be sure it matches what the sections are.They can be different.The settings for the GPS should be checked to be sure they are correct. I had a problem when I went from Viper Pro to Viper 4 getting them correct.
