1 - 16 of 16 Posts
We finished up harvest and unlike the last couple years have time now to do fall work. For me that involves baling a bit of straw round and square for my wife's pets..... any way here is a couple old relics that get hooked up once every one or two years do a small job and get shoved back into Bush till next time I need them.
Wondering what you use hardly ever but know after you air up the tires and grease and oil up a few parts it still gets a job done for you. 20181026_114040_1540697519531.jpg 20181026_122308_1540697629031.jpg
Discussion Starter #4
That **** W4 is my little go to small chore tractor.... crank start only... but as long as it's not colder than -10 outside it starts if not on the first crank 2 or 3 the colder it is outside. I love it, it's been on the farm since before my time.
R John Deere my dad bought oh so long ago. Pick a few rocks with it just to lube everything up. My left arm got strong as a kid cranking the steering wheel on the old girl. Easy on fuel is an understatement. An old 50' set of diamond harrows gets pulled out once in a while too. Works great in disced up areas.
Hehe I also have an old WD-9. One of the ones that starts on gas and you have to switch over to diesel. The old girl was retired and parked against an old shop. After I got married and we moved a house onto the farm the wife say it and had me drag it to the front of the house. Planted a bunch of trees/shrubs around it. It’s the first thing you see when you drive into the yard. Kinda a nice resting place for the old girl
Long time lurker, first time poster. Dad and I must have been really bored in 2014 so we got his old WD-9 running as well as Massey Harris 90 Combine that we bought at the neighbors auction sale. Truth be told, we bought it for battery as it was $25. Anyways Video explains it all and I had a blast running the old stuff. Now due to the 10 post rule about posting links. Give the title of the video a copy and paste if you got the time, thanks.
Massey Harris 90 combine with International WD-9 tractor YouTube
Rebuilding a 4700? Vibra-tiller, think its 52 ft but it's been in the weeds for 15ish years, never thought I would ever drag it out again!
What are you rebuilding, the trips? My shanks are getting wore but mostly had to replace some springs as they get stretched from when a shovel catches on a buried boulder and gets pulled back further than had been designed. I have the 49 foot version. Watch the bearings on the walking beams, never had them fail but every once in a while need to snug them up just a bit.
A 16’ Deere 100 chisel plow drug out about once every three years to fill in water runs created in spring by runoff.
Little of everything, got new sweeps on, got new harrow teeth in the other day. Bunch of new tires, hydraulic hoses (cant believe them cheap originals made it this far, I dont think they even have steel braids)
I had a bunch of bent shanks and a couple broken ones. Few springs that must have been pulled too hard cause they are bent in the middle.
It will get me through what I need to do this fall with it but the rockshaft tube has been patched and the bolts through the shanks are only acceptable.
The shanks themselves are in pretty nice shape, when we bought it back in the 90's it already had the plastic wear strips on so that helped a lot.
Kinda suprising how reasonable tillage parts have been, I think by the time I'm done I still won't have 5 grand into it, tires and hydraulic hoses have been by far the most expensive.
Mine might be a 49, I think they said it was 52 but never put a tape to it. Been planning on measuring the spacing, I thought when I ordered 100 sweeps I'd be good but I came up like 5 short. Must be 6" spacing, I was thinking 7.5"
Ha ha, I was going to post the same thing except mine is a 14'. Tires hold air and the greasable bushings in those wheels have lasted longer than any Bourgault wheel bearing I have ever seen. Done lots of breaking with that thing.
If you guys want old I sometimes use a couple of old stone-boats to drag stuff around, those must be 100 years old...
Discussion Starter #15
Thanks for sharing!
I'm posting a link to your video.
https://youtu.be/rZOW7K5TBe0
We have an old A-C gleaner combine.... we try to leave a half width sheath for it to do end of season but last couple years harvest has ran too late.
Ya I had to do some tires on mine few years back already and mine still has those nylon braid plastic hoses but the covering is all falling off so like you, one of these days gonna replace them all. The small diameter ones for the wings are the worst, the full size actual lift lines are still intact.
Spacing on those is oddball, its just over 6.5 inches, 6.7 to be exact, must have been something in Cornbinder's wisdom with an oddball number like that lol. I've had to move a few around on mine to make it more able to deal with trash, but with that deep frame spreading the ranks they do work well.
We'll both have the same five section main frame, book actually calls it 48, and if yours has the two extension shanks on each end outside the frame, then that is what they call 51. Funny though when you measure them they come out a foot bigger lol.
If you need any tech on cylinders or anything or tooth patterns just ask, I have the book for mine.
1 - 16 of 16 Posts
