So it looks as if we are very close to making a deal on a 56ft 1870 conservapak with a 550bu 1910 cart. The question I have is we have a TJ530 with twin pumps and I know it is more than capable of running this unit but we would rather keep out TJ on our 58ft NH drill as it will be a harder pulling unit and the tractor handles it better in wet conditions. Our other tractor is a 9380 case, it pulled the 58ft drill for 2 years before we bought our TJ so we know it is capable of just being hooked up and running the NH drill.
Ideally I would like to hook the JD drill to the 9380 because the drill will be easier draft/ easier to pull in wet then the NH unit so I would like to run it on the case. Has anyone run the new 1910 carts with an older tractor? Would the 30gpm closed center hydraulics be enough for this unit? If not its not a big deal and we will switch it up but like I said, ideally I would like to run it with the case. Just looking to see if anyone has run one of these on an older tractor. There is one guy around here running a twin tank 430bu setup with a 9370 but he has an auxiliary drive on the tractor so I know we will have no issues pulling this unit, hydraulics are our hangup right now.
