I would never use. I know some people that tried it and put on the plastic sprockets. It never worked. They want back to steel in the middle of harvest which was not something you want to have to do at that time. I think the lugs stripped off the sprockets. Some have tried to line the feeder house with puckboard too and the straw works its way underneath and bulges it - that never worked either.
If you want it to run quieter, put in the roller/silencer kit (rod all the way across). Remember that the metal slats on a feeder chain never wear out. They are easily brought back into shape. With header off, put in a crowbar at the drum and straighten. My chain slats are not always straight but rounded up in the middle due to high MOG. That doesn't seem to matter, only really matters when a rock gets in and gives the chain a bad cant which does have to be taken out to be straightened or replaced. If I had a newer combine with 3 sprockets/chains on, I would seriously go back to 2 when it wore out. The stress on the upper shaft on the 3 chain system often breaks the top shaft. If you keep the feeder chain looser, you can get at least 1000 hours of use out of it. Think of the MOG as your natural tightener. If you tighten up the feeder chain and then add straw under it, you eventually can stretch the chain, leading to its early failure.
