21 - 33 of 33 Posts
Whoa! What's the explanation on the trim then.
A lot of the crew that put these buildings up are hacks.
Its not overtight screws. If you left the screws loose enough that they didn’t pull the metal tight to the 2x6 the metal would fall off in a year. It is not wind damage either, the metal would bend out from the screws.
It is most certainly cupped 2x6’s. They either cupped after installation and pulled the metal in (maybe not kiln dried enough) or they were cupped on installation and the installation crew should have stopped building and waited for different 2x6’s.
I would either take the payout or have the metal and 2x6’s replaced. My guess is that it was poor quality lumber.
That's a mess them wankers don't deserve the pay , either dished or cupped perlons or over tensioned screws and rough iron handling has done that... shame on them , start posting them photos on their companies Facebook and web pages.
You deserve new iron at the least, I would also involve your insurance company as they won't be keen to insure that.
Discussion Starter · #26 · (Edited)
Thanks everyone for your comments and feedback, I appreciate it.
Here is the reply from the Praire Post Frame Engineer.
"Dear Recipient: I am writing this letter in regards to the 4 photos that were sent to ------from --------- on October 5th. Firstly, I would like to note that the lighting conditions can greatly effect the appearance of the metal siding. From viewing the photos, it appears that the kinks in the metal siding are due to bowing/cupping of the lumber purlins supporting the metal. The screws supporting the metal panels must be tightened sufficiently to compress and seal the neoprene washers to prevent moisture infiltration. The bowing/cupping is an inherent property of the lumber and is not within the control of Prairie Post Frame. -------- of Prairie Post Frame was on site to assess the building and adjusted some screws. It is of our opionion that nothing else can be done and that the minor kinking of the panels is consistent with industry standards."
If the lumber was cupped slightly they should have flipped it over and it could have been fine as long as the screws holding the metal were centered on the 2x6. If the lumber was severely cupped they should have got new lumber. Bottom line is lack of craftsmanship. Big problem nowadays. Nobody gives a $hit. As far as their response about screw tightening, that is not correct. Sure the washer has to be compressed but the metal also must contact the wood beneath it. What they are advocating would leave a gap between the metal and wood and would lead to obvious problems down the road. As for the trim job, well I’m sure Miss Anderson’s kindergarten class could have done better. Don’t back down.
Here is the reply from the Praire Post Frame Engineer, I've redacted names as my lawyer is now involved.
After consulting with my lawyer, if he said I was good to go, i would plaster those pics WITH that statement ALL OVER the net, anywhere that someone that may want a pole shed might hang out. I can't imagine ANYONE hiring PPF after seeing those pics and reading that response. "industry standard" my a$$. "PPF standard" apparently but NO WAY industry standard.
I think ill be sending PPF a email cancelling my quote for a new pole shed !! Don't care if they are cheaper with that type of response and workmanship ...!!! Screw them!!!...... no pun intended
21 - 33 of 33 Posts
