1 - 2 of 2 Posts
I was wondering if anyone put the poly feed plate on there 1020 flex head. I was considering buying the poly feed plate from poly tech and the poly underneath the auger. If anyone has that installed how do u like it? Does it work well in soybeans?
I installed a couple of polytech bottoms and also their poly plates. The pads under the head works great and is easy to install. I put the pad on both LH and RH corners. It beats any riveted pad under the head especially on the Y bar under the wobble box side
1 - 2 of 2 Posts
