Are power chips worth the money, what brands are the best, are they difficult to install, looking at installing them in a 9660sts and a 9600. Any help would be appreciated
I would say they are worth the money, Shoup MFG has the cheapest prices Ive seen. I noticed a difference in fuel usage in a days run after adding the programmers. I use a bullydog from SHoup for the 9600 and it works well.
We had our 9650sts chipped with a chip from saskatoon diesel, in saskatoon, saskatchwan,canada. www.dieselservices.com all he he wanted was the serial and model # of the pump and he made us one that was selectable with a toggle switch 15% or 30% (no, you couldn't switch one the go when loosing power,have to shut the motor down,would be nice though). i'd say it was worth the effort.
With the Schlagel chips I've sold there's always been an increase in fuel economy. As far as warranty, they unplug in seconds and are not traceable on the ecu. The local dealer has been good with turning a blind eye. A lot of Deere dealers actually sell chips right over the parts counter.
We have a schlagel and a bully dog and while they both make more power on the dyno that they are rated I personally like the bully dog for the 3 position switch
this is true but you have to know were to start.you will start blowin relief valves.all you are doing is telling the ecu that rail pressure isn't at desired.
We have a John Deere Combine 9500. from 1996.
What is the problem when you switch to to half engine speed nothing happens? it only work on idle and full speed.
Considering purchasing 4640 display with auto track as opposed to activating auto track on the 2630 display. Any experience using 4640 display on combine?
I have a 9860 STS runs but only just at 270RPM checked fuel coming out of tank and screen there and fuel filters they seem ok, any other suggestions? What fuel pressure should I be getting at the filter housing? Any help much appreciated.
